RCU Forums - View Single Post - Will changing the fuselage from square to round effect it's handling?
Old 02-19-2009 | 04:04 PM
skeeter_ca's Avatar
skeeter_ca
Default Will changing the fuselage from square to round effect it's handling?
I have a Super Sportster 60 kit i'm building and want to add a little zing to it. I have a 1/6 pica ymf-5 radial cowl. I want to mount it on the front of the fire wall and create round formers down the box frame of the SS fuselage. I would sheet the front portion and use stringers for the rear portion with fabric covering. The horizontal stab, vertical stab and wing would remain stock, except for flaps added to the wing and maybe rounder wing tips. So the the question is....Would the plane still have the good handling qualities that Super Sportsters are known for or will it have a negative impact?
skeeter
