RE: Proper prop balancing
Some times a prop is so far out of balance that a mere scraping of the the back side of the heavy blade or painting of the light blade will not suffice.
You must remove more material, perhaps from the top of the heavy blade also also.
And then you will find that you must remove material from one side of the prop hub to ever get it to balance
