RE: Surging motor
Ok, thanks for the info. I have several 3 cells lying around that I can probably use... forgot what capacity they are, but they should work. The motor should be fine. Ultrafly Rimfire. It should run at about 8 amps or so as it is set up now, and the ESC/BEC is a 12 amp.
CGr.
