RE: mCX Binding Problem
How do you have it set up in the radio? Helicopter or airplane settings? Either will work. If heli, which swash mode? It should be set on "Normal, 1 servo". Set up in one of those settings and re-bind. If that doesn't help, try adding throttle trim until the blades start to spin, then back it off a click or 2 until they stop.
