Beasley1 wrote:
... You wouldn't have any video of that running would you?
so far only one published on youtube, only the first moves in very slow speed there are to be seen. Also the sound of the chainsaw is terribleā¦ There are still a lot of works to achieve a presentable level.
Dirty_Vinylpusher wrote:
Beasley1 - ... That must weigh a fair bit, no?
perhaps did you mean me? this ride weighs 50 kg (nearly 23 lbs), that is too much. I strive for 30 kg (nearly 14 lbs) at a new one.
drewcrew6 wrote:
Beasley1: ... how much do you run it?
perhaps did you mean me? I did not reach yet the limit because of problems with weight and steering as well as the work on the new model. Starting from 50mph would be acceptable for me.
