RCU Forums - View Single Post - DL-50 Engine Temp
Old 02-21-2009 | 10:02 AM
jack1933
Default RE: DL-50 Engine Temp
After many years building and running engines, cylinder temps can run up to 300- 400 degrees on a test stand or in the plane, with a ir gun and the area around the spark plug painted flat black These temps are perfectly normal, if lower then the engine is not producing maximum horsepower.
