RE: CA glue in the torque rods
Acetone is the active ingredient in the debonders and a lot cheaper at the hardware store. It is also nasty stuff use gloves and in the open. Definately give it a try. I like to slop grease on the torque rod before construction, just about any kind of grease vaselene etc. for this reason then there will be no problem. If the rods are prebent then you can still work some in on both ends by sliding as far as it will allow.
