RCU Forums - View Single Post - Mixture Setting
Old 02-21-2009 | 01:04 PM
bonebreak's Avatar
bonebreak
Default RE: Mixture Setting
If the engine is too rich, it will die when you give it throttle, or bog down. Yes, the two turns mean tighten the needle until closed, then loosen it two full turns or 720 degrees.
