RCU Forums - View Single Post - Hyperion 260 40e
Old 02-21-2009 | 03:59 PM
victorzamora
Default RE: Hyperion 260 40e
I'm really underwhelmed by the thrust numbers I'm getting from Motocalc. I plugged in the Scorpion 3026-12 as suggested, and with the APC 13x8E it was only showing 83oz of thrust. That's only 5.2lbs of thrust. With a 13x6 it's only showing 90.6oz (5.66lbs). Also, it only showed the motor pulling 49.6A. It's showing 610W, which is a little anemic...isn't it? Am I doing something wrong?
Thanks for the RCG tip, I'll check that out asap. Also, I'm thinking about the 90A Scorpion ESC.
