RCU Forums - View Single Post - Landing
Thread: Landing
Old 06-11-2003 | 06:14 AM
GRANT ED's Avatar
GRANT ED
Default Landing
I have found that different people favor slightly different techniques. I remember being told that you should try to make the plane fly to the end of the strip when landing by holding off. This is also a technique used in flying full size GA planes. However, i found that doing this caused a lot of problem for a beginner. This is i think is due to the fine control needed. I have seen many newbies try this technique and end up having the plane stall at about 1 foot in height causing it to drop hard onto the runway. This is a good idea for more experienced people who have the ability to hold the plane off the ground a couple of inches. While learning i used a similar style but once the plane was slow i would try to set up a slow decent rate and let it touch down. Not the most professional style but worked for me while learning. The plane however must be going slow enough to touch on the main wheels first or you will bounce
