RCU Forums - View Single Post - throttle routing-4 stroke
Old 02-22-2009 | 09:41 AM
CB36
Default throttle routing-4 stroke
Hi all;
I'm getting ready to swap out an OS61 for a Magnum 91 4-stroke in my Tiger 60. The carb is behind and in the middle of the Magnum. That will place it close to the firewall. Since the throttle arm is in the center of the engine and close to the engine's body, I'm looking for a way to rout the pushrod. The fuel tank is located in a compartment directly behind the firewall, so I have to come out near the fuse side. I've installed a Saito before by bending the pushrod back on itself to attach, but this one doesn't look like that will work. Suggestions?
Thanks!
