RCU Forums - View Single Post - throttle routing-4 stroke
Old 02-22-2009 | 10:44 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: throttle routing-4 stroke
ORIGINAL: LesUyeda
CB36. If you do as Minnflyer suggests, be sure to put a piece of insulation over the wire so that you do NOT have metal to metal contact. I used teflon tubing for my similar system.
Les
I was assuming that the throttle arm was nylon (They usually are on a 4-stroke).
But yes, if it's metal put a piece of shrink tubing over the wire.
