RCU Forums - View Single Post - Kevlar fuel tanks
Old 02-22-2009 | 10:58 AM
  #31
Props4ever
Default RE: Nitro Tank
ORIGINAL: Kevin_W
Props,
I have used both West Systems epoxy and Vinyl Ester resin for making tanks. I prefer West Systems by far.
Aeropoxy (as in BVM Aeropoxy, or Hysol 9462) is not a laminating resin, it is an epoxy glue. That is what I use for joining tank halves once they are molded and gluing in fittings, but it is not acceptable for laying up kevlar or fiberglass parts. You need a laminating resin for that.
Thanks Kevin for coming on here and explaining us bit more in detail information i was actually looking for. So this pretty much sums up as long as resin is epoxy it will work and will not get affected with glow fuel.
Here is the Aeropoxy resin i use mostly for my fiber glassing jobs. I understand there is another epoxy glue brand out there also with the same name as the brand of resin i use.
Sam
