RCU Forums - View Single Post - throttle routing-4 stroke
Old 02-22-2009 | 03:58 PM
CB36
Default RE: throttle routing-4 stroke
ORIGINAL: LesUyeda
CB36. If you do as Minnflyer suggests, be sure to put a piece of insulation over the wire so that you do NOT have metal to metal contact. I used teflon tubing for my similar system.
Les
Thanks all...I just don't quite understand the insulation suggestion. I thought that was only if you had a gas engine? Anyway, the throttle arm on the carb is metal.
Can you explain how I go about this? For some reason, my brain is not wrapping around this concept.
Thanks!!!!
