RCU Forums - View Single Post - another darn ryobi post (ryobi performance modification, analysis and comparison)
Old 02-22-2009 | 05:41 PM
aj0nr
Default RE: another darn ryobi post (ryobi performance modification, analysis and comparison)
It is great to see all the other info about the Ryobi.I have torn apart about 20 of them and found alot of differances with them. 1 the lower part with the crank,two differant sizes,some of them have been milled in production and some are cast and cleaned up, also the front seal/bearings are differant on some of them.The outside case,some are wider than others.2The heads,the newer Ryobi's with the "E-Z start "in the title are the ones with the compresion vents that go up the sides for emisions complience.I could go on and on,BUT I have found an older engine that was dated 1978 that had 2 rings on the piston and the rod was forged aluminum and held to the crank with a bolt( name was 'Piston Powered Products model # 99).The other one I have is a Troy built/MDT dated 3/2006 also has two rings on the piston,But this is the new casting I have heard about .The lower crank case has the magneto shield as part of the casting.This will require much more work to convert.
