RCU Forums - View Single Post - another darn ryobi post (ryobi performance modification, analysis and comparison)
Old 02-22-2009 | 10:04 PM
aj0nr
Default RE: another darn ryobi post (ryobi performance modification, analysis and comparison)
I was able to see the differance in the front seal after I dropped one.oops.It was a long shaft with the seal on the front then bearring.I could see a 1/4- 3/8 " space in there.I have 7 short shafts with the seal first and only one that has the bearring first.Long shafts ,4 with seal first and 6 with bearing first.Some of the motors were Ryan or other type,and the rest are Ryobi.2 large bearrings one far forward and one aft next to the rod/counter weight.
What is everybody doing to replace the mag space when you put on the EI conversion??
