RCU Forums - View Single Post - vibrating plane
Thread: vibrating plane
Old 06-10-2003 | 04:31 PM
Eugoogoly
Default vibrating plane
earlier on today i made a bigger oppening on the cowling at the carb so i could see into the carb better for setting the engine, but now when the plane is sitting at idle the plane vibrates like crazy, more than it has before. could this be beacuse there is less of a restriction of airflow to the engine thus causing it to run lean. if so would i need to reset the needles?
Pete
