RCU Forums - View Single Post - vibrating plane
Thread: vibrating plane
Old 06-10-2003 | 04:41 PM
Montague
Default vibrating plane
One thing is sure, you won't reduce vibration levels with a needle valve setting. You might change the engine RPMS, which might change the aparent or actual vibration of the engine, but that's it. But as you change throttle settings, the vibration will change anyway.
