G-62 stock new at horizon hobbies.
http://www.horizonhobby.com/Products...ProdID=ZENE62A
Mine starts pretty easy, but its relatively new. G-62's like to be primed dripping wet out of the carb. There is a technique to starting, most call it slap the crap out of the prop. Its really not as bad as it sounds. But you have to orient the prop exactly as it says in the instructions. Then you have to make sure you follow through so the magnet passes the coil at the fastest speed during the flip.
Edwin
