RCU Forums - View Single Post - stupid question, can i use forward and reserve esc instead of vpp
Old 02-23-2009 | 01:18 PM
Rodine Air Force's Avatar
Rodine Air Force
Default RE: stupid question, can i use forward and reserve esc instead of vpp
If you open the pitch too much you will not get much of a thrust. I set the pitch curve end point between one and two amps over specified max current for the motor. This way I got the most thrust
