RCU Forums - View Single Post - What To Expect From A 4-Stroke
Old 02-24-2009 | 01:19 AM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: What To Expect From A 4-Stroke
if you bought a brand new engine....you shouldnt have to mess with anything other than the carb like you would on a 2 stroke the valve lash should be fine factory,,,, the key IMO opinion to get that put put put put idle , is to set the low end right on....to rich and will idle rough, too lean and the idle will fade, and die when you try to throttle up
