RCU Forums - View Single Post - What part of the build do you like the least?
Old 02-24-2009 | 02:36 AM
Hircflyer's Avatar
Hircflyer
Default RE: What part of the build do you like the least?
ORIGINAL: Popriv
I pretty much enjoy all of it EXCEPT, Sanding the bevel on the control surfaces.
I dont know why but I've been putting it off, I started last night.
I even made a larger version of the tool they have you assemble from the kit that guides the sand paper.
2nd worst is setting up the front wheel. always have trouble figuring out where to file the flat spot on the shaft.
Steve
Try using ti-angle sock glued to the trailing edge of wing/stab and the leading edge of ailerons/elev/rudder. Presto no sanding bevel
