RE: JetJoe OWNERS thread
Hi Paul,
Long time no see. I have bought a new fuel pump which is similar to flight works pump from jetjoe. But the worse thing happened to me. The pump has too obvious strong performance on fuel supply than old JJ pump because start EGT went up rapidly to 900 degrees within a few seconds. Long flame out of rear cone scared me. I had to reduce the setting of start point to auto+0 and of start ramp to 001. The second start still failed due to hot start at the end of start phase.
Do you know there is lower setting of start than auto+0 and 001 in REGAL semi-auto ECU? Thanks a lot!
