RCU Forums - View Single Post - SLOW COMBAT RULES.....SORTA!!!! :)
Old 02-24-2009 | 10:33 AM
Wiggy
Default RE: SLOW COMBAT RULES.....SORTA!!!! :)
Combatpigg & Richard,
Thanks for the pics. I will get something going with this as time permits. Here is a Parker/Flying Z "Combat Pig" that we used to fly with .32s. They are quite different now.
I also took a couple pictures of my other combat stuff. First is the Wild Thing 15 with 36" span. It is fun to fly but too easily destroyed in combat.
This is a J&C Funbat that we flew in Florida for a short time with 15s also 36" span. They were about $20, if memory serves me correctly, and my Flat Bat we called the "Frigate" because we were flying rudder as opposed to ailerons. It has a 48" wing that I cut from 2" Home Depot foam with 20 degree dihedral and 6 degrees of sweep with 1/4 square spars, top and bottom. I have a jig to cut the slot for the spar so it is straight while the wing panels are swept. It made the center much stronger. We used .25s on these for RCCA combat.
I have been through the SPADs and scale combat routine as well. I want what every combat pilot wants, the build once fly forever, combat plane!
Billy
