RCU Forums - View Single Post - TT .46 Pro Failure
Old 02-24-2009 | 07:07 PM
XJet
Banned
Default RE: TT .46 Pro Failure
Since the front bearing is just a couple of bucks it makes good sense to change it anyway. Can't hurt and also means you won't have to use a puller to remove the prop-driver, you can just tap it out like I show in my video.
If you *do* tap the crankshaft out you do need to change that front bearing because the balls may be brinelled by the force of the tapping.
