RE: AE Mini MGT 3.0 carb settings?????
What do you mean by remove the battery? Do you mean the glow plug ignitor? To answer your question, yes the condition of the glow plug is very important... The way you test the glow plug is to take it out of the engine and put it on the ignitor if it lights up fast and a really bright orange color its good, if it seems somewhat dim or doesn't light up at all then its bad........ The ignitor is important as well, it should have a really good charge I'm guessing your using the stock one that came with the mgt rtr kit, if so make sure the "D" battery your using is still good or brand new..........
