RE: High start temperature
Hello,
First, let me say that 900 degrees on a P-80 is FINE, if I were you I would not worry about it.
My guess is that the pump might have broken in some since new and is pumping more fuel for a given voltage.
If you want to experiment, you can lower the Uaccel1 and Uaccel2 voltages a bit (maybe 1-2 units at a time) and I am sure your temps will drop.
To change these values, hold the "Limits" key down and then press "+". This will bring up a sub menu to change the 2 voltages. After you change the voltages with the "+/-" keys, press any blue button to save the values and exit.
Let me know how it goes.
Regards,
