RE: Substitute for Ether
hi boys, today ive tested, or re-tested the same blend... Im starting the engine by hand, OK, today I feel that the engine is no steady, have only power in high compression, no idle (it is a CL engine, w/o carburettor).
when I decrease the compression, the engine begin to swing without sound of explosion... now, I'm not sure if is the fuel or the prop, or both.
I'm using a 10x5 wood prop in a paw 29ds
