RE: Beach/Dunes
Running at the beach is a lot of fun but if you have unsilled bearings they will need replacing after you are done. If your air cleaner is not hard mounted tie wrap a piece of panty hose around the air filter and carb neck so that you cant loose it in a wreck. Any sand in the carb and your engine is toast. If you don't have paddle tires get some they will make the experience one to remember.
