ORIGINAL: ArloRogers
Running at the beach is a lot of fun but if you have unsilled bearings they will need replacing after you are done. If your air cleaner is not hard mounted tie wrap a piece of panty hose around the air filter and carb neck so that you cant loose it in a wreck. Any sand in the carb and your engine is toast. If you don't have paddle tires get some they will make the experience one to remember.
+1!!!; also, remember to get any sand out of the bearings when u are done by blasting it out with compressed air and the like...because otherwise like arlo mentioned; u may need to replace them because the sand can mess everything up if ur not careful....
