Blade CX2 Problem, any suggestions?
Hello everyone. My name is Michael, and Im having an issue with my Blade CX2.
I am using the stock controller it came with LP5DSM. The issues I am having are,
First, when I attempt to turn the heli by left hand control stick to the left the heli doesn't respond at all (when moving it to the right side the heli turns as normal) Also, the heli when in air (which is very unstable ATM) keeps veering off to one side no matter what trim settings, etc I try. While im sure this is connected to the prior issue I wanted to include this as well.
I have replaced a few parts today in attempt to solve this issue (needed to be done anyway, but none of this helped)
Replaced the outer and inner shafts. The Outer shaft retaining collar, and the bearings that fit in the body for the outer shaft.
The only "upgrades" I am currently using is an aluminum lower rotor head, and a carbon tail boom (version from Mircoheli)
Any suggestions would be greatly appreciated. Thanks!
CRAP! I forgot one extra addon I've installed. Sorry, but I also have installed a "Heatsink" as well.
