RE: RCBEE Gear & Door Sequencer
I just purchased the RCbee sequencer from Todd at Dreamworks and installed it in my Fei Bao Rafale
I did some experimenting with the automatic fail safe operation... this feature alone was really worth the money!!!!
No more broken Gear doors due to turning on the transmitter with the switch in the wrong position.
One comment though, the manufacturer needs to have someone proof read the English instructions.
It still will not prevent mishaps when people bump your retract switch when your jet in sitting on the ground.
Here are the test results:
Gear initially in Down position (Gear Down Storage position or Flight ready mode)
1) Transmitter Off - Turn on receiver, the audible beeper starts beeping and the gear down LED flashes, gear will stay Down.
2) Transmitter On, Gear switch in Up position - Turn on Receiver the audible beeper starts a beeping and the gear down LED flashes, gear will stay Down.
3) Transmitter On, Gear switch in Down position - Turn on Receiver audible beeper beeps once indicating normal operation and the gear down LED goes to a solid on indication, gear stay Down.
Gear initially in Up position (Gear up Storage position)
1) Transmitter Off - Turn on receiver, the audible beeper starts beeping and the gear down LED does not illuminate, gear will stay Up.
2) Transmitter On, Gear switch in Down position - Turn on Receiver the audible beeper starts beeping and the gear down LED flashes, gear will stay Up.
3) Transmitter On, Gear switch in Up position - Turn on Receiver audible beeper beeps once indicating normal operation and the gear down LED does not illuminate, gear will stay Up.
