RE: Idle problems
Sometimes this same symptom can be due to having a rich idle. When someone sets the idle speed based on a rich idle mixture, when it is revved up the engine clears out the excess fuel that has accumulated. Then it idles faster for a bit until the rich idle mixture causes it to slow down again.
In any case, as mentioned, the engine should be tuned properly.
AV8TOR
