RE: What am I doing wrong?? (Adding fibreglass)
Hi gisi with your epoxy brush sread athin layer of epoxy on the bare wood then lay your glass down on the epoxy you just put on then brush on another layer of epoxy on the cloth make you put enough on to soak the cloth if its a little thicker then you want it to be take a old credit card and scrape alittle off just make sure the cloth is soaked with epoxy if you want it to real smoth take your heat gun and warm the epoxy up just be aware this speeds up the curing prosess let cure good then lightly sand as needed good luck[sm=49_49.gif]
