RE: CRRC PRO GF26I
Does the large part of the propshaft that threads onto the crankshaft go all the way down flush with the surface of the gold prop hub or does it stick up slightly above the serrated surface of the hub?
Timing should be set at 28-30 degrees BTDC, sometimes they get set to far advanced or you may just have a bad module.
