RCU Forums - View Single Post - Straight solid shaft vs Flexishafts
Old 06-11-2003 | 01:56 AM
AltimaT
Default Straight solid shaft vs Flexishafts
The problem with a straight shaft is the U-Joints required to get the driveline parallel to the water at the prop. I true and polish my flex cable ODs to try to reduce friction some, and try to use the largest possible radius bends in the stuffing box. I would like to try piano wire like the electric guys are now using. The smaller the diameter, the less friction. Something around 3mm might work on a .45???
