RCU Forums - View Single Post - BH MODELS (CAP 232-80)
Old 02-27-2009 | 07:16 AM
JIMMYMUGUREL's Avatar
JIMMYMUGUREL
Default RE: BH MODELS (CAP 232-80)
Hi James,
I bought one a few days. I have to put an engine of 45cc Chainsaw. I have two questions. How did the engine located? Mouting templates for OS MAX are right axle with 11mm (0.4 inches). You mounted the engine to fit in the cowl or used for mounting the axis for OS MAX. You have reinforced the wall of fire, it seems a bit fragile? What weight is your engine? Mine are completely 1865g (4.11 lbs).
Thanks for your help.
Best regards,
Mugurel
Jimmy and Mugurel
