kamlooper,
If you haven't started yet, the fuse sides are 1/32" with 1/8" stringers but you can use 1/16" for the sides if you want to strengthen it a bit. The ribs are also from 1/32" but again 1/16" can be used. The spars and tail are from 3/16".
Remember that the all up weight should be less that 1kg. 900g or less is recommended otherwise you won't be able to hover this plane.
I'm still working on the updated plans with descriptions of the parts in english. I'll post it here in dxf format once I finish it.
