RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 02-27-2009 | 07:50 AM
  #1069
Schummie
Default RE: CMP BF109F BUILDING THREAD
Hello guys,
Had to make some adjustments, for my CG was way off to the back of the plane.
Both my lipo’s had to be placed as far forward as possible. I glued in a battery bay, as can be seen in the picture. To make room, the electronic retract valve had to be replaced to the center.Also the convertor and the receiver with power box is placed as far forward as possible. I chose the left side for the lipo’s to keep it also left/right balanced.
The CG now is 116 mm, exact in between 112 and 120. This is the range suggested by CMP.
Please, especially the guys hwo have already maidened their plane. What CG did you use, and did you keep it there after your flights. To get the CG more forward, I would have to place lead in the nose.
I rather want to prevent that, as the plane already is 13,4 pound.
Thanks in adcanced for sharing your CG settings with me.
Regards,
Eric Schumacher, Netherlands.
ID:	1145989   Click image for larger version
