RE: Help needed in programming Futaba 10c
no but I've got one and will help if I can, but to start from the ground up might take some time, and how much do you all ready know, i.e. have you got you name for your mode in the 10c, and then it's what head i.e. H3 ect it's the way the servos move the rotor, then set up the end points and what will need reversing, use the display "servos" to see what each servo does and how they all work to move the head, it's one of the neat thing the 10c does, and how it compares with what the servos do in real life, one thing that court me out was the throttle, better to low than to high so set half throttle for 40% and 6 degree's of pitch, well for a starter,
use vr switch's for the pitch and throttle fine tuning,
I check this site most days so if and when I can I'll answer any questions, but your need a few day's just to get the basics, but it's well worth it,
well this should keep you busy till tomo,
