RCU Forums - View Single Post - Seagull Ultimate
Old 02-27-2009 | 09:44 PM
  #59
Sierra11861's Avatar
Sierra11861
Default RE: Seagull Ultimate
I am almost done building this model and I have run into one problem that I can't seem to solve easily. I used the 3 X 40mm screws for the elevator posts instead of the reccomended 3 X 30mm screws because they lined up much better with the fuse exit holes and did not bend the control rod all to hell and burn up the servos. Now I am left with no 3 X 40mm screws for the ailerons. I bought some 3 X 40 mm screws at the local hobby store and when I got home I realized the threads did not run the length of the screw so I could not tighten them on the control surface so they turned out to be useless. Wow, what a nightmare. I e-mailed Seagull models and, no surprise, I got not response. I googled 3 X 40mm screws and got nothing. Anyone know where I can get 2 lousy 3 X 40mm screws!!! Thanks in advance
