RCU Forums - View Single Post - Fiberglassing - help
Old 02-28-2009 | 03:03 PM
OldScaleGuy's Avatar
OldScaleGuy
Default RE: Fiberglassing - help
As for the masking problem, one thing to try is to mask off the surface, then spray a layer of clear coat or the underlying paint color over the edges of the masking tape. That seals the paint line, so your top color shouldn't bleed through.
This a great method. You can also you the same base color of paint and achieve the same results. Either way will work fine.
