RCU Forums - View Single Post - BVM Mig-15 question
Old 02-28-2009 | 04:25 PM
Silver182's Avatar
Silver182
Default RE: BVM Mig-15 question
ORIGINAL: swansons
I have just finished my BVM Mig-15 powered by a JetCat P-70. The overall dry weight came out at a little over 23 lbs. Bvm states the top weight should be 22 lbs. Will this be a big wing loading problem, or will it still fly OK?
The BVM main gear are squatting already. Is this a characteristic of this particular type of gear?
I need some advise from you Mig-15 builders. BTW it is the newer A.F.S. version kit.
John S.
Hi John,
My MIG-15 was the earlier all built up version. Originally the kit & gear was designed to be powered by a D/F, the D/F versions came in around 17lbs. The main landing gear springs were designed for that weight. It sounds like your gear need to be modified by removing the springs, and replacing them with stronger ones.
Order two from Century Spring Co. Inc. Los Angeles, Ca. (213) 749-1466. At one time all you had to do was call them and they would send you two for "testing" hoping you were going to order a box full I guess. Anyway they mailed them with-in a couple of days at no cost.
The catalog number is NN-79; you'll have to cut them slightly for proper length!! When you install these the MIG will then sit up better not so tail low. The tail low look is neat, but part of the bounce on landing problem others have had is do to the nose wheel tending to touch first and touch with more spring!
Lee H. DeMary
AMA 36099
