ORIGINAL: diamondave
What do you think for throttle then? still stay away from the 225's? i wouldnt think the saito 82 shakes that much, but its been a long time since ive flown glow, either the 425 or 625 i suppose, the 625 may help with balancing? extra weight up front ya know
I've had a 225MG in mine for the throttle since last May and have flown it a lot and no problem with the 225 so far. Have had some serious vibrations also at times with motor mount bolt failures but no servo problems. Think I finally solved the motor mount problem by glueing some aluminum stock on both sides of the motor mount area and mounting my .82 to that. Sure has helped so far with no more broken bolts and most of vibration seems to be gone. If i ever build another I'll do that from the beginning.
