RCU Forums - View Single Post - Failed servo.
Old 03-01-2009 | 01:13 PM
  #31
Flyfast1
Default RE: Failed servo.
ORIGINAL: Spychalla Aircraft
I am glad to see that P-40 driver put "Isolated" on the description of the battery packs. That is key. Dual batteries are not much better than one stand-alone battery if they are not isolated. Failure in one pack just quickly drains the second pack down.
2. Closed circuit Battery Failure (a.k.a. Fried the Pack) - On a single pack system it is over. On a dual pack system that is not isolated it will quickly cook the second pack.
Leo
Leo,
According to information that I've read elsewhere, such as Red Schoefield's Battery Clinic and some testing results that were posted somewhere here on RCU, it's not a problem to use two packs without diodes. According to the testing that was done, a failure in one of the packs caused only a very slow drain on the second pack. My recollection may not be correct, but I thought that after an hour, the remaining "good" pack was only drained by 10% or so. The conclusion of the testers was that with regular checks of battery voltage, e.g., between flights, or every other flight, that the risk of a failed pack draining the other pack and bringing down a plane was extremely low. I generally use two 6v receiver packs into two ports on a receiver on all my planes and am interested if you have more information on this approach. I would like to better understand the scenario you are thinking about.
-Ed B.
