ORIGINAL: jonlowe
I've read every post here, but I'm not sure if the kit works with the non-low oil version of the 1.70 or not. Can I use the kit with a standard 1.70 using a high oil content, or do I have to have the new crank? Is the magnet for the sensor in the crank pin, or is it in the supercharger that comes in the kit?
Jon
The first one I ran just about one year ago was a standard 170 and ran perfect on 20% oil. The ignition will work fine whether your on 20% oil or 10%. The engine needs to be leaned down and will burn a little less fuel with the lower oil. The crank and the exhaust lifter are the two different componnets that allow the connecting rod bushing to survive with only 10% oil.
Bill
