RE: servo lead chokes, are they useful
The servo chokes are used mostly on gassers that tend to develop RF problems, usually on the throttle servo. I was getting a lot of glitching on one of my gassers and tried the choke on my throttle servo, no help. I then changed the RX and what do you know, problem solved. I found the antenna was falling off that RX on the inside of the case so problem found. I still have that choke but I never have figured out if it works/helps or not. As engeneers would you guys call RF noise and electrical problem or not?? That's all the chokes were used for.
