RCU Forums - View Single Post - Triton Discharge Problem
Old 03-02-2009 | 06:34 PM
nraheja
My Feedback: (15)
Default RE: Triton Discharge Problem
A123 are certainly the best, but to answer your specific question w.r.t Triton's capability (settings) to, If the packs have not been used over the winter, I would run them for 3 cycles Chg/Dshcg at 2A to 2.5A /1 A rescpectively. Make sure you have the voltage at .8/cell and dial down the peak sensitivity to 3 mV to 5 Mv.
I had the same problem with 2 year old packs from Hang times and the above settings, got the pack back between 85% and 90% capacity. Also set the peak delay to 0 min...
This should work provided the packs are not too old.
