RE: First Time Flap Set-Up
OK, I've got the flaps set up on the three position switch, everything is moving in the right direction and I've adjusted out the binds using the linkages. With the switch in the fully deployed posiiton, I can use the endpoint adjustment on each servo to match the travel. I do not have any adjustment available in the middle partially deployed position. Is there a way to use the radio to exactly match the flap travel at the intermediate position. If so, I haven't figured it out yet.
Thanks for your help.
Bob
