I'd like to know the total weight of the plane witht he small gas engine. The wing area on this plane is a little small for a gas engine and I'd be worried about the high wing loading
If weight is needed up front to balance this plane then a small gas engine my just be the trick. How much do you think your plane will weigh with you gas engine and what gas engine are you planning on using.
